Technical Questions
Old Feb 27, 2005 | 08:09 PM
Ohoneandahalf's Avatar
Ohoneandahalf
Default RE: Technical Questions
4) Porting increases airflow, thus adding power by allowing more air into the engine.
10) I've seen a Subie WRX here in AZ that is already turboed and has a supercharger added. Pretty neat design how they piped everything.
Old Feb 28, 2005 | 12:21 AM
ZachW04Stang's Avatar
ZachW04Stang
7. To do a burnout in an automatic you hold the brake and punch the accelerator at the same time. In a manual you depress the clutch and rev the engine up then while holding the accelerator at a high rpm you let go of the clutch.
Old Feb 28, 2005 | 09:17 PM
Casper98GT's Avatar
Casper98GT
I ♥ Acer
Supercharging and turbo charging at the same time huh, what are they running for Compression ratio?????
Old Mar 1, 2005 | 09:18 PM
Ohoneandahalf
Not sure but the supercharger will make up for the turbo lag. It's kinda like having staged twin turbos.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
