is it worth it?
Old Nov 2, 2007 | 11:49 AM
fanaticstang15's Avatar
fanaticstang15
Default is it worth it?
I have 96 3.8L V6 and I want to upgrade to a GT, the guy I bought it from says the car is set for the 4.6 but im not sure about the electrical system or the suspension. Is it worth building a new motor and converting to a GT? If not under what circumstances would it be worth it?
[align=left] [/align]
Old Nov 2, 2007 | 03:44 PM
GreyStang's Avatar
GreyStang
Default RE: is it worth it?
It would be worth it only if you were able to do all the mechanical work yourself. If you need to hire a garage to do the swap, forget it. It'd be much cheaper to sell your car & buy a GT
Old Nov 2, 2007 | 04:37 PM
dr0pt0pGT's Avatar
dr0pt0pGT
definitely not worth the hassle...
unless... you love working on cars, can do everything yourself (some things will require an additional set of hands), and you have lots of money to spend on it.
i had a 95 3.8L 2 years ago. (best motor every built BTW) ...blew it up and put in a carbed 5.0 from an older mustang. it was fun and exciting to do it myself but after everything was said and done I had prolly put over $2500 into the swap. I did go a little crazy with the March Performance Pulleys and all the chrome but still. If you've got the time, patience, and money... go for it. Otherwise, sell it and buy a GT.
here's a little encouragement...
my final product...
and a little help...
http://www.mustang50magazine.com/how...wap/index.html
Old Nov 2, 2007 | 06:32 PM
fanaticstang15
Thanks guys! that helps more than you might think
Old Nov 2, 2007 | 11:14 PM
MU71L4710N's Avatar
MU71L4710N
i seriously doubt it was "set up" for a 4.6 alot of people sell bull**** along with their car.
set up for a 4.6 means he putthe following:a new bellhousing (which i donno if it will even bolt to the 3.8 in the first place), 8.8 or beefed the rear end, stronger suspension up front, bigger radiator, etc... you would still need to do something with the ecu and you need a 4.6 wiring harness which wont be done with a 3.8 still in the car.
Old Nov 2, 2007 | 11:23 PM
fanaticstang15
I am not sure about the bell housing but the transmission is not the original T-45, the rear end is the 8.8 and the suspension stiff as all hell, however I am not sure about the raidiator either. I didnt know about the ecu and wiring harness though, Thanks!
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
treesloth
Sep 28, 2015 07:03 AM
fastbackford351
Convertible Tech
Sep 27, 2015 06:51 AM
2015Ecoboost
Sep 17, 2015 01:48 PM
showoffzx2
4 Cylinder NA and Turbo
Sep 14, 2015 08:40 PM
