serious problems
Old Nov 5, 2007 | 01:07 AM
tow mader's Avatar
tow mader
Default serious problems
I have a 94 mustang GT. It is smoking super bad, eating gas like cake and everyday is its birthday and wont shift out of second. There aren't many mods, just a MSD ignition, chip and a K&N. I really need some suggestions. I believe the shift problem is because of "limp mode", it is almost like the fuel pressure regulator went bad. When you turn the ignition on (not starting the car) you can hear the fuel pump whinning, and a hissing noise at the rails. I am lost. This is my first ford. I am born again...previously a Chevy Fanatic.
Old Nov 5, 2007 | 04:20 AM
NJcobraEkul's Avatar
NJcobraEkul
Default RE: serious problems
on the fuel rail there is a nipple. key on wait or the fuel pump to kick on then press in the nipple on the fuel rail if theres fuel take a look at the injectors. that could be the probelm. (possible clog in the fuel rail)
Old Nov 5, 2007 | 04:46 AM
tow mader's Avatar
tow mader
I tried that. The fuel pump continuosly runs and so does the radiatorfan. I unplug all wires from the throttle body and it still smokes like a chimney. it is overloading on fuel for some reason.
Old Nov 5, 2007 | 11:39 AM
tow mader's Avatar
tow mader
how do I check if the computer is gone bad
Old Nov 5, 2007 | 11:56 AM
88Mach1's Avatar
88Mach1
http://www.troublecodes.net/Ford/
Old Nov 5, 2007 | 09:46 PM
Colorado_Mustang's Avatar
Colorado_Mustang
Sounds like the fuel pressure regulator.
mungodrums
Oct 7, 2015 04:01 AM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
tmdm
Sep 4, 2015 06:45 PM
Sep 3, 2015 07:14 PM
