possible tie-rod problem
Old Nov 7, 2007 | 05:23 PM
footwart23's Avatar
footwart23
Default possible tie-rod problem
one of my front tires leans in at the top,out at the bottom. would this be a possible tie-rod issue? ? maybe needs a toe-in? thanks
Old Nov 9, 2007 | 12:52 AM
eviljeanyis's Avatar
eviljeanyis
Default RE: possible tie-rod problem
First make sure your Stang is on flat ground and not on a hill or pothole whichcan mislead the eyeball alignment. Other than that, have it checked at by shop.
Old Nov 9, 2007 | 07:44 AM
Chopper's Avatar
Chopper
You need an alignment.
http://www.miracerros.com/mustang/t_....htm#Alignment
Take the car to a reputable shop to have this done.A shop that has the newest Hunter alignment machine is the one to use.
A car that shows signs of neglect likeyours could vey possibly need several parts to bring everything back into spec.
Old Nov 10, 2007 | 06:43 AM
footwart23's Avatar
footwart23
thanks for the info. that is some very useable material. just one of the tires has a lean to it. thats why i thought maybe a toe-in was all it might need. i guess i'll be going to the alignment shop. thanks
Old Nov 10, 2007 | 07:11 AM
Chopper's Avatar
Chopper
Toe in or out isn't your problem,it's thecamber that's out of spec.
Old Nov 11, 2007 | 07:06 AM
footwart23's Avatar
footwart23
thanks,i believe you are right. thanks again
Seanam
Oct 4, 2015 10:15 AM
mdj89
Sep 23, 2015 08:49 AM
kachuy10
Sep 22, 2015 01:27 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
