help with vent system....
Old Mar 2, 2005 | 10:56 PM
BOSSMAN's Avatar
BOSSMAN
Default help with vent system....
when I turn the vent on or a/c the air flow comes out the top and bottom not through the vents like it should, when i mess with the switch it eventually works after some time..any suggestions on what I should do???
Old Mar 3, 2005 | 11:31 AM
C/Note's Avatar
C/Note
I ♥ Acer
Default RE: help with vent system....
ORIGINAL: BOSSMAN
sounds like you lossing vacuum to your a/c maybe ?? check your lines for intake to going inside to the case ,,maybe you canister is leaking...???or got bad vacuum element??
Old Mar 3, 2005 | 12:12 PM
96SilverLT1's Avatar
96SilverLT1
yup, sounds like a vac leak. there should be a vac line heading into teh firewall from the motor. Make sure that has vauum. there should also be a check valve there. Make sure thats functioning. Then start inside and find where it's bleeding off. A hand held vac gauge/pump from autozone is a good tool to help you find this problem.
Old Mar 3, 2005 | 12:13 PM
BOSSMAN's Avatar
BOSSMAN
thanks guys I will give it a shot
Old Mar 3, 2005 | 12:30 PM
C/Note's Avatar
C/Note
I ♥ Acer
[sm=americanasmiley.gif][sm=bounceybounce.gif]
mrtrodonet
Sep 19, 2020 03:12 PM
PaulH2
20
Jan 31, 2016 09:48 AM
Beerman309
Sep 19, 2015 01:16 AM
tmdm
Sep 4, 2015 06:45 PM
