Fuel system supporting 800HP?
Old Mar 3, 2005 | 11:42 PM
Mustangous's Avatar
Mustangous
Default Fuel system supporting 800HP?
I have a 90GT that when i am finished painting, I will be putting together a 800hp combination(hopefully). So i am going to start with the fuel system. I know the basics, changing the pump in the tank, adding an adjustable fuel pressure regulator, and injectors, but i know this wont support 800 hp boosted. I was looking into the Aeromotive kit but it only supports 700 hp boosted. So can anyone point me in the right direction for all the components from the tank to the fuel rails. I am trying to make this car as clean as possible and hopefully show it when i am all said and done so how i mount things will be also in consideration. Will the aeromotive kit be a good foundation and just have to get a bigger fuel pump? Oh, i am also trying to stay away from a fuel cell and am considering the aeromovite direct replacement fuel tank or getting a sump kit and installing. Any help would be greatly appreciated.
Troy
Old Mar 4, 2005 | 02:21 AM
BCisme's Avatar
BCisme
Default RE: Fuel system supporting 800HP?
your gonna need a big *** pump and big *** injectors. that'll prob be the main issue. maybe even bigger fuel lines.
Old Mar 4, 2005 | 02:46 AM
Mustangous's Avatar
Mustangous
I have been looking into the aeromotive kits and i am thinking about the Eliminator kit. It supports 900hp forced induction and its around $1500. But i guess my other option is weldon kits? Does anyone know if the FMU is a good idea for the aeromotive kits?
Old Mar 4, 2005 | 06:47 PM
vfast's Avatar
vfast
I ♥ Acer
I don't like fmu's period........I would used a 255 in tank and a 255 inline pumps. go with a bigger line also maybe a sump for the fuel tank...you'll need 72's to start with and those so call 700hp kits will work fine..1500 for their setup is just robbery..so I take it will be a turbo correct....you'll need some 225 afr's with plenty of work..should use a F.A.S.T. system with it
angeljoelv
SVT Forums
Sep 10, 2015 09:12 PM
Sep 10, 2015 08:39 PM
robjh22
Suspension
Sep 8, 2015 12:47 PM
Sep 8, 2015 11:50 AM
Sep 1, 2015 08:16 PM
