Comp Cams XE278AH
Old Jan 1, 2008 | 03:04 PM
strtfab87's Avatar
strtfab87
Default Comp Cams XE278AH
Hello, ive got an 01 GT 5 spd. I recentaly purchased the comp cams XE278AH #102700. I have heard that im going to have some serious problems installing these cams and getting it to run right. If i did get them installed i was going to take my car to either Pauls High Performance in Michigan or BobKurgan Motorsports in Illinois. Could u give me any info on what could be soem problems and if these cams are to aggressive. My mods are as follows
BBK Long tubes
BBK X pipe
SLP LM I
FRPP 4:10's
UPR short throw
Typhoon intake manifold
UDP
CAI
TB
Plenum
Tune
centerforce dual friction clutch
Old Jan 2, 2008 | 09:28 AM
Chopper's Avatar
Chopper
Default RE: Comp Cams XE278AH
These cams are the largest in the PI series and so have the largest gains.These gains come above 4,000-4,500 rpm though.To realize the potential of the cams you're going to need a port and polish job and a set of fly-cut pistons.The pistons will need this valve relief to keep piston to valve contact out of the picture.
I notice from your list of mods you havent hadvalve reliefsdone yet.It is required!
The gears (4.10's) will work well with this cam due to the high rpm rangethey run.
I would suggest you go down one or two steps in your cam selection.The X 262 AH is a good street cam and no internal modifications are necessary.
It's always better to have too small of a cam than one that's too big.
A P+P job is always good no matter what cam you choose.
Old Jan 3, 2008 | 02:16 AM
tbirdscwd's Avatar
tbirdscwd
^^^^He's right. People even have trouble with the 270s.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
patchshaffer
Tuner Central
Oct 5, 2015 02:24 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
junior04
Sep 28, 2015 10:53 AM
