My DD is smoking
Old Jan 15, 2008 | 07:05 PM
Valcore's Avatar
Valcore
Default My DD is smoking
The coil went bad in my 93 cutlass 3.4 DOHC ever since I replaced it the car smokes, but only when i first start it. Afterten seconds it dosn't smoke anymore (but it does cause a huge embarrasing cloud of smoke). What could cause this?
I know it's not a mustang but I can't find any one or where else that knows what to do.
thanks
Old Jan 15, 2008 | 09:24 PM
fourfivefour's Avatar
fourfivefour
Default RE: My DD is smoking
Valve seals are the most likely cause.
Unless you are mysteriously loosing antifreeze then possibly a bad head gasket.
Old Jan 15, 2008 | 09:49 PM
Chopper's Avatar
Chopper
If this is the first start in the morning or after a day long shut down and the smoke smells like burning oil,then it's probably valve seals.
If it does this after even a short time of sitting then it's probably a head gasket leaking/seeping.The smell will be like sweet steam (?????).This will get worse until the day it gives up and completely blows and leaves you stranded.Like fourfivefour said,"If you're losing coolant it's probably a head gasket".
Jan 21, 2016 01:30 PM
RCS02v6
Sep 29, 2015 01:46 PM
MacSerio
Sep 27, 2015 01:05 PM
Ipaman
Sep 22, 2015 07:01 AM
fastbackford351
Sep 12, 2015 09:42 AM
