Heater problems
Old Jan 24, 2008 | 08:23 PM
rwdfan's Avatar
rwdfan
Default Heater problems
My heater only gets warm, its still blows well. But just not hot. Could it only be my heater core? Or could it be something else? 89 mustang 5.0
Old Jan 24, 2008 | 09:02 PM
Phantoms's Avatar
Phantoms
Default RE: Heater problems
I have the same problem with mine. I have replaced the thermostat, coolant sensor, and temp switch. Still only gets warm. I am getting ready to change the water pump and get a power flush and fill done. I was told that I might have a clog in the heater core which is not allowing the heat to get hot. I'll let you know if the flush and fill worked or not.
Old Jan 25, 2008 | 01:04 AM
93_five_oh's Avatar
93_five_oh
it could be the climate control ****... well the adjuster behind it.
when you turn the ****, it adjusts a flap behind there that directs the air over the heater core or over the a/c... mine came loose once and wouldn't blow hot air. i fixed it when i changed the heater core.
Old Feb 2, 2008 | 03:50 PM
rwdfan's Avatar
rwdfan
So, anyone else? Im thinking its not my thermostat, because temperature gauge is normal. The water pump is brand new, was replaced by the previous owner. So either a plugged heater hose, plugged core, a faulty temperature ****, or something else?
Seanam
Oct 4, 2015 10:15 AM
mdj89
Sep 23, 2015 08:49 AM
kachuy10
Sep 22, 2015 01:27 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
