Electric fans
Old Mar 27, 2005 | 04:05 AM
83GLXRAG's Avatar
83GLXRAG
Default Electric fans
Has anyone installed a Black Magic fan and have 300-350 hp with stock radiator? I was told I need a Flexalite extreme duty for 300hp using stock radiator, and for 350 hp I need that fan and a alumium radiator.
Old Mar 27, 2005 | 04:22 AM
Quik's Avatar
Quik
Default RE: Electric fans
alot cheaper fan is a LS1 or Lt1 fan from a fbody. they can be found for cheap and flow a good amount. i also heard that a tauras fan flows great also. save money go find bone yard one. i got a Lt1 set in my car
Old Mar 27, 2005 | 11:36 AM
stanglx2002's Avatar
stanglx2002
i was looking at the new black majic extreme for my car since it flows 3300 cfms compared to the regular fan with only 2500 cfm.
Old Mar 27, 2005 | 11:44 AM
vfast's Avatar
vfast
I ♥ Acer
also can use the one from a lincoln....I would also go with atleast a 3 core rad....I.ve seen the around 130.00 shipped..I use a flex fan myself
Old Mar 27, 2005 | 11:46 AM
stanglx2002
you can go with a lower thermostat too like a 180*
Old Mar 27, 2005 | 06:01 PM
C/Note's Avatar
C/Note
I ♥ Acer
ORIGINAL: 83GLXRAG
i got a blk magic fan with alum rad...got 600 rwhp i think ?? runs warm only when i forget to turn it on....[]
Old Mar 27, 2005 | 11:01 PM
88GT40's Avatar
88GT40
summit has aluminum radiator custom fit for fox stang on sale for 309 bucks
part number
bci-65011
a cooler therm and highflow water pump and a dual puller fan would be optimum but if you have your heart set on the black magic go for it.
Old Mar 27, 2005 | 11:04 PM
stanglx2002
you could does get a 3 core radiator for like $120
Old Mar 27, 2005 | 11:10 PM
88GT40's Avatar
88GT40
i had a three core that works good too but it will not lower you front end wheight, so an aluminum will be lighter and alum dissapates heat better. so you get what you pay for
Old Mar 28, 2005 | 11:28 AM
stanglx2002
there not that bigger of a difference between the weight of the 2 radiators
