Engine code help?
Old Mar 28, 2005 | 03:11 PM
94droptop's Avatar
94droptop
Default Engine code help?
Hi all, i need some help i havea bad 02 sensor the code reads says its on bank 1 position 1 which side is that? is it the one inside the intake manifold
Old Mar 28, 2005 | 03:19 PM
96SilverLT1's Avatar
96SilverLT1
Default RE: Engine code help?
Front 02 on the cyl number 1 side.
Old Mar 28, 2005 | 04:00 PM
94droptop's Avatar
94droptop
how can i tell which side is the number one cylinder
Old Mar 28, 2005 | 08:10 PM
Djs94stang's Avatar
Djs94stang
On 5.0, its on the left front as you are looking at the engine. Also, look closely at the distributor cap (I'm assuming from you name it's a '94) there is usually a "1" on the number 1 cylinder plug wire marked on the dist cap.
Nick Oliver
Oct 17, 2018 04:22 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
zanemoseley
Sep 6, 2015 12:58 PM
zachary1988
Sep 4, 2015 03:04 PM
