MAF Which one to get!!!
Old Mar 29, 2005 | 12:36 AM
pena8759's Avatar
pena8759
Default MAF Which one to get!!!
Hey All. Just a question. I am in the market for a new MAF, I was looking into the C & L they seem to be good. Also like the idea of that the sampling tube can be switch. What size should I go with 73mm of 76mm? I will also take any suggetions. Thanks in advance.
Old Mar 29, 2005 | 01:29 AM
fordguy17's Avatar
fordguy17
Default RE: MAF Which one to get!!!
i don't think it matters what size you pick. its only a 3mm difference. just to let you know a bigger maf sensor will yield you absolutely no gain unless you get a bigger t/b too.
Old Mar 29, 2005 | 09:51 AM
bobby's Avatar
bobby
no, it will help SOME but not NEAR as much as if you get a TB along with it. if you CAN, get a PRO-M. theyre the best, get a 75mm one, and get a 70mm TB. I know im gonna get people telling me that its too big and get a 65mm TB, bu TRSUT ME, ITS FINE!!! you will have MORE than enough airflow up to 800hp!
Old Mar 29, 2005 | 10:01 AM
stanglx2002's Avatar
stanglx2002
i hae a C&L 76mm MAF on my car
Old Mar 29, 2005 | 06:37 PM
luckythirteen13's Avatar
luckythirteen13
i have the 76mm on my car. works great. as long as the maf is larger then your tb youll be fine
Old Mar 30, 2005 | 10:07 AM
Djs94stang's Avatar
Djs94stang
By looking at the website...it looks like the 73mm is for stock injectors and with the 76mm you need at least 24lb injectors.
Old Mar 30, 2005 | 02:40 PM
luckythirteen13
you can choose any size injector for either size
Old Mar 30, 2005 | 02:52 PM
Djs94stang's Avatar
Djs94stang
Not for mine...at least according the website. For 94-95 they show stock 19 lb injector only under the 73mm. For 76mm they have them for 24 lb and up...unless the info is wrong. For 86-93 what you said is true.
Old Mar 30, 2005 | 02:56 PM
DIVER8374's Avatar
DIVER8374
So do I need to get a new MAF for my car seeing how I have installed a 75mm tb & c&l plenumn? And if so what performance gain will I see with one and what size do I need to get??
Old Mar 30, 2005 | 03:02 PM
stanglx2002
http://www.cnlperformance.com/80mm_96-01.html
here you go and it says an increase of up to 16 HP
