idle issue, after IAC Mod
Old Feb 5, 2008 | 10:25 PM
00blackstang's Avatar
00blackstang
Default idle issue, after IAC Mod
So i made the IAC Gasket, so the revs drop quick..... The revs do drop quick, but now my car at a light is idling at likw 1100rpms... When it use to at like 800. Any ideas?..... i figured it was because i disconnected the iac so the computer would adjust to it, but i drove around for a while and it was still idling at 1100.
Old Feb 5, 2008 | 10:48 PM
timeformiller44's Avatar
timeformiller44
Default RE: idle issue, after IAC Mod
no its because you changed the airflow of the IAC...and now its going to work harder and rev higher to stay running... because the hole u make is smaller...so if it idled at 800 itd prob stall bc not enough air flow...so it has to rev higher...so IAC mod ... ull idler higher
Old Feb 5, 2008 | 10:59 PM
00blackstang
When i put the restrictor plate in my 2000 it idled the same
Old Feb 5, 2008 | 11:29 PM
timeformiller44
well thats diffrent...
the IAC mod.. your making the hole it was programmed with DIFFRENT...its going to change a lot of thigns
2007StangV6
Jan 28, 2016 06:09 PM
Roush05
Sep 10, 2015 12:23 PM
zanemoseley
Sep 6, 2015 12:58 PM
RWHEELS
Sep 5, 2015 03:42 PM
Emblazoned
Sep 3, 2015 10:45 PM
