rearends
Old Mar 29, 2005 | 07:08 PM
79special's Avatar
79special
Default rearends
which rearend is better? the 8.8 or the 9 inch? i want to go with rear disc. should i try to find a rearend with discs already on it or just get a rearend and convert it?
Old Mar 30, 2005 | 01:42 AM
fordguy17's Avatar
fordguy17
Default RE: rearends
9 inch is stronger, but doesn't have as much aftermarket support. it is also overkill if you aren't running 500 hp with sticky tires and regularly dump the clutch at 5k. a well built 8.8 will last quite some time. how much hp are you putting to the ground?
Old Mar 30, 2005 | 01:53 PM
79special's Avatar
79special
Well the car isn't together yet. Just trying to plan out the parts and stuff right now. I want about 300hp.
Old Mar 30, 2005 | 02:11 PM
fordguy17's Avatar
fordguy17
in that case i would build a nice 8.8.
Old Mar 30, 2005 | 02:53 PM
roundman's Avatar
roundman
ORIGINAL: fordguy17
9" Ford rears don't have as much aftermarket support??? You've got to be kidding, right?? There are more 9" Ford rears used in all kinds of race cars than just about any other rear there is out there and the parts available for them are damn near endless too. You can get a much larger selection of gears for a 9" compared to an 8.8 also since they are used in all types of racing from drag to sprints to NASCAR and others. I do agree you don't need one if all you want is 300 HP.
Old Mar 30, 2005 | 03:07 PM
79special's Avatar
79special
Should I buy a new 8.8 or get one from a junk yard or something. And what about the rear disc conversion?
Old Mar 30, 2005 | 04:46 PM
primetime5.0's Avatar
primetime5.0
they have built 8.8's going 9's in 03-04 cobras
Old Mar 30, 2005 | 04:50 PM
79special's Avatar
79special
My particular stang is a 79.
Old Mar 30, 2005 | 07:48 PM
horseshoeing's Avatar
horseshoeing
I would fotget the disc brakes on the back. They are a waste of time and money. I have them on my car because they came with my 9in. rearend.
Old Mar 30, 2005 | 11:32 PM
Obsol3te's Avatar
Obsol3te
ORIGINAL: roundman
ORIGINAL: fordguy17
Was about to say the SAME thing
Well not as detailed, but around something like that[&:]
Well, you can't go wrong with the Ford9".
You say you only want 300hp now, but what about when you get bored of that?
