cam lift 390 fe block
Im taking out a .548 lift hydraulic cam, and I want to go with a .560 solid lift cam. I run stock steel heads and will upgrade the valve springs accordingly. Is the .560 to big? will I run the chance of a valve hitting a piston? Any old school FE big block guy's who can give good solid advice? Thank you
ORIGINAL: 390hipo
Good Luck.
