brake prob guys help quick!!
Old Feb 23, 2008 | 10:25 PM
F5GTS331's Avatar
F5GTS331
Default brake prob guys help quick!!
ok so my 94 gt's brakes started acting up on me this week. the pedal wants to travel all the way to the floor. ok so maybe it's a master cylinder????? it had pedal after it sits for awhile then the more you push it the moreit goes down and eventually to the floor in ten times or less so i swapped the master cylinder today and in the process of bleeding i'm not gettin anymore fluid to my rear brakes what the crap is going on here?????? it doesn't even had much fluid at the abs box is it the proportiong valve or bad new master cylinder or what?
Old Feb 23, 2008 | 10:46 PM
BLK89GT's Avatar
BLK89GT
Default RE: brake prob guys help quick!!
proportioning valve cloged not to sure on the spelling
Old Feb 23, 2008 | 11:00 PM
F5GTS331's Avatar
F5GTS331
so what do i need to do?
Old Feb 24, 2008 | 12:13 PM
F5GTS331's Avatar
F5GTS331
bump
Old Feb 24, 2008 | 12:48 PM
ewgoetz's Avatar
ewgoetz
I would start off by checking all your ruber brake hose's. Make sure none of them are kinked, swolen or damaged in anyway. You will have 3 of them 2 in the front and 1 in the rear right above the diff. May also take a look at all the steel lines, make sure none are damaged.
S197 Shelby Section
Aug 27, 2015 02:08 PM
bond007
Aug 26, 2015 11:36 PM
Fast-Hands
Aug 19, 2015 06:54 AM
cvarner131
Aug 17, 2015 07:38 AM
FD725
Aug 11, 2015 03:43 AM
