Narrowing 8.8 rear axle
I have an 8.8 axle from a ranger and would like to narrow it for installation on a '32 ford I'm building. It costs several hundred dollars, or.......
Can I pull the axle shaft out, get it shortened. Then line up the empty axle housing carefully in the band saw and cut out a 3" section of the housing out, near the end where it tapers, but not on the taper. Then place the housing end back on (with the bearings and seal still in place) then put the axle shaft back into the axle to hold everything in alignment. Then carefully clamp the pieces together so that the cut piece of the axle housing is flush all around with the housing and then tack it together and then weld it. A little bit at a time so that it doesn't overheat the bearings and seals that are 6" away from it.
Anybody have any reasons why or why I shouldn't do this?
thanks
thanks
ORIGINAL: MattM
thanks
thanks
I like this way of thinking this is rat rodding and on a 32 hellyea . keep it dead centerd durring mock up work off a string line . I would cut it in the middle of the axlle tube to make the weld easyer .clamp 4 peices of angle iron to the tube to keep it straight durring the weld up the pipe joint should be back bevled as far as possable with at least 4 root beads get the unit mounted and be shure it is stright before you send the axles out to the mechean shop to get cut and splined . the axles are diffrent leanghts driver side and passnger side so keep that in order to
Sounds like it will work but like lucky said it will be week. I would get it professionally done. I think there is a place you cann buy narrowed dana rear ends, I can't recall their website though. I'll see if i can find it.
Nov 10, 2015 11:39 AM
TfcCDR
Sep 14, 2015 12:08 PM
Sep 10, 2015 08:39 PM
Dragonus18
Sep 9, 2015 01:21 AM
