compression test
Old Feb 24, 2008 | 12:19 PM
lexy's Avatar
lexy
Default compression test
hey checked my cylinder compression test, It ranged from 110 min and 125 max. Is that good? Did it on a totally cold engine.
Old Feb 25, 2008 | 01:04 AM
lexy's Avatar
lexy
Default RE: compression ratio
Anybody?
Old Feb 25, 2008 | 07:44 PM
blstoff's Avatar
blstoff
compression ratio ??I think you mean you checked the cylinder compression . anyway , that sounds a littlelow to me . did you crank the engine over at least 4 compression strokes ??
Old Feb 25, 2008 | 07:47 PM
89gt347's Avatar
89gt347
^^^ +1 on sounding low. I think it should be around 180 - 200 psi.
As stated above make sure it turns 4 compression strokes then take the reading.
Old Feb 25, 2008 | 09:40 PM
ericdk5.0's Avatar
ericdk5.0
And every cylinder should be within 10% percent of each other.
Old Feb 26, 2008 | 11:52 AM
lexy's Avatar
lexy
The cobra is bored .20 over. got manley pistons and rods. I don't know if that has anything to do with it. Also when i checked the car was cold. Meaning i haven't driven it at all. Yeah i did do 4 strokes, or till the needle stopped moving.
baddog671
Jul 26, 2016 01:20 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
GT350 S550 Tech
Sep 29, 2015 03:29 PM
