Tokiko illumina adjustments
Is there any certain way to tell the markers for the 5 settings in tokiko illumina shocks? I bought the car and all i have to go by is the red adjustment slot in the top with a little white indent. no way to tell what setting im on. Any suggestions?
well if i were you i would just move the setting one way as far as it would go and put a mark of some kind there. then if it rides really soft you would know to go the otherway with it
You can't just move the adjuster all the way to one way b/c it just keeps going around. There should be numbers 1-5 around the pointer that you turn. If it rides really hard it's probably set on the firm side, you can adjust it to ride a lot softer.
