o2 sensor location?
Old Apr 4, 2005 | 03:50 PM
94droptop's Avatar
94droptop
Default o2 sensor location?
I need to replace a pre cat o2 sensor on bank one where will it be located?
Old Apr 4, 2005 | 03:53 PM
fats429's Avatar
fats429
Default RE: o2 sensor location?
behind the headder on the exhaust pipe
Old Apr 4, 2005 | 03:54 PM
94droptop's Avatar
94droptop
which side?
Old Apr 4, 2005 | 04:10 PM
fats429's Avatar
fats429
this does not make sence . the cat's came out around 1970's EFI came out in the 80"s if you are talking right bank you got MP EFI 1986 and up. the H-pipe yo got is aftermarket . the EFI wont work withh out the O2 sensor you should have at least 2 and they are right behind the headder
Right bank is passsanger side
thare is no such thing as pre cat EFI gasoline engin
Old Apr 4, 2005 | 05:06 PM
bmorrisj's Avatar
bmorrisj
i think he means pre cat as in , in front of the cat....
the 02 sensors are the only things with electrical wires on your exhaust....
Old Apr 4, 2005 | 05:14 PM
94droptop's Avatar
94droptop
i meant before the cat i jacked up the car and found out it WASN"T plugged in, but the code is still coming up. it says heater circuit malfunction o2 sensor bank one
Old Apr 4, 2005 | 05:20 PM
bmorrisj's Avatar
bmorrisj
drive the car for a few minutes and let the computer re-learn conditions with the 02 plugged in....
Old Apr 4, 2005 | 05:24 PM
94droptop's Avatar
94droptop
i did i drove around the block came home turn it off turned it on it came back on, i went to advanced auto to get it checked and he cleared it then i turned it on drove like 2 minutes turned it off and the code came back
Old Apr 4, 2005 | 05:30 PM
bmorrisj's Avatar
bmorrisj
have you tried new o2's yet.... if you switch one out, might as well swap out the other one so you dont have to worry about it later.....
Old Apr 4, 2005 | 05:31 PM
94droptop's Avatar
94droptop
i havent replaced the o2 yet it is in a tight *** spot i have one universal one that i am putting in i am waiting for the engine to cool
