weird? reverse burnout but not forward?
Old Apr 6, 2005 | 08:00 PM
Edx2x's Avatar
Edx2x
Default weird? reverse burnout but not forward?
I can burnout in reverse but not in drive... weird or is that normal?
Old Apr 6, 2005 | 08:01 PM
Albizo66's Avatar
Albizo66
Default RE: weird? reverse burnout but not forward?
Ever think you were facing the wrong way? lol
Old Apr 6, 2005 | 08:05 PM
OneGearhead's Avatar
OneGearhead
thats definitely wierd. what gearing you got in the rear ?? granted reverse is geared WAY LOWER than your forward gears, but, no matter what, you should be able to spin your tires however much you want to, unless its a 2.3 or something to that effect.......maybe you need a tune-up.......REALLY BAD !!!!!
Old Apr 6, 2005 | 08:29 PM
Obsol3te's Avatar
Obsol3te
Sounds like my 2.3!
It can only make the tires squeel when in reverse.
Poor car, should prolly pant Escort over the mustang lettering
Old Apr 6, 2005 | 09:42 PM
dan's Avatar
dan
its because of the weight transfer, when you go forwas the weight travels to the rear and puts more pressure on the tires, when you go backward the weight travels foward and you have LESS weight on the rear, making it very easy to spin. Thats why your front brakes do most of the work
Old Apr 7, 2005 | 12:14 AM
Edx2x's Avatar
Edx2x
it seems like I spin them a bunch but I don't hear the squeal... i do have a speaker box in the trunk, maybe that makes a difference? but yeah i cant even do burnouts when i hold the break and try
Old Apr 7, 2005 | 12:27 AM
fordguy17's Avatar
fordguy17
you might be stomping on the brake to the point where the rear brakes lock up. only use as much brake force as necessary.
Old Apr 7, 2005 | 12:32 AM
Edx2x's Avatar
Edx2x
when I do that i just start slowly going forward, do my tires grip too much? it seems like from the line im real slow but from 20-40 im REALLY quick... think somethings screwy with my computer?
Old Apr 7, 2005 | 12:48 AM
Marty256's Avatar
Marty256
I assume (bad) that you're power braking and have drum rear brakes. Two reasons. One reverse is a lower gear than 1st. Two brakes are made to have more holding power for forward rotation so they have less holding power in reverse. Larger shoe to the rear. It called servo self energizing shoes are made to wrap inside the drum. Hope this explains the phenom.
Old Apr 7, 2005 | 02:20 AM
IownaMustangNow's Avatar
IownaMustangNow
seems a lil wierd. But thats what you get for driving an automatic :-D
