T-5 Transmission conversion
I could use some sound advice, as to my options.
I am converting a 1965 Mustang from automatic to the 5 speed T-5 transmission. In my infinite wisdom
the one I purchased is from a 1994. Knowing now that in the 94 and 95 the input shaft is longer. Here are my options as I see them. Spend the $200.00 and order the correct shaft or will a 94 bell housing bolt up and plan on cutting the floor another 2" back.
Any thoughts or other ideas would be greatly appreciated.
the one I purchased is from a 1994. Knowing now that in the 94 and 95 the input shaft is longer. Here are my options as I see them. Spend the $200.00 and order the correct shaft or will a 94 bell housing bolt up and plan on cutting the floor another 2" back.Any thoughts or other ideas would be greatly appreciated.
