power outlet
Old Mar 15, 2008 | 12:01 AM
ScottXL's Avatar
ScottXL
Default power outlet
i saw someone else here with the same problem but he didn't get an answer. so i'll ask again
on my sn95 stang my power outlet stopped working as well as my cigg light. where is the fuse located? it ried to google it but i couldnt find it anywhere.
any help?
i'd like to get this fixed asap.
Old Mar 15, 2008 | 05:48 AM
corvetteguy's Avatar
corvetteguy
Default RE: power outlet
On my 89 it was the HORN fuse in the standard
fuse block.
Old Mar 15, 2008 | 06:28 AM
andysm's Avatar
andysm
In my 01 GT my power outlet quit working but the cig-lighter still works. Have checked every fuse under the kick plate and can't find I can't find one blown. I thought that the outlet itself had just went bad. I had a Motorola cell phone charger hooked to it, and have seen at work where these chargers actually melt down while charging. So I figured the charger burned it up or something.
I too will be interested in the responses in this thread.
Old Mar 15, 2008 | 12:54 PM
ScottXL's Avatar
ScottXL
ORIGINAL: corvetteguy
fuse block.
foxbodies are a lot different than sn95's in term of fuses and such.
Old Mar 15, 2008 | 01:07 PM
MustangMike2001's Avatar
MustangMike2001
There is a 20amp fuse in the relay box under the hood that powers the outlets.
Old Mar 15, 2008 | 02:50 PM
ScottXL's Avatar
ScottXL
Do you know which one?!
EDIT:
after a bit of searching i found this site:
http://autorepair.about.com/library/faqs/bl039g.htm
it's for a gt, but i assume they use the same fuse box. here's the problem, i checked the fuse that's supposed to be for the cigar lighter, but it wasn't burnt out i even switched it with another 20a fuse that was in there and still nothing. any help?
Old Mar 15, 2008 | 03:45 PM
MustangMike2001
That's not the same, at least not as mine. Check out the pic.. The one you want to check is "Maxi 9" the bright yellow one in the pic.
Old Mar 16, 2008 | 12:54 PM
ScottXL's Avatar
ScottXL
ORIGINAL: MustangMike2001
Alright, I fixed it. But it wasn't Maxi 9, it was Mini 18. It was a 25 amp mini fuse, and I should've seen it sooner, it was all discolored and old looking. Even if it wasn't blown, it looked like it needed to be replaced anyway.
Old Mar 16, 2008 | 03:59 PM
andysm's Avatar
andysm
[:@]All my fuses look fine. Oh well.
Old Mar 16, 2008 | 09:27 PM
ScottXL's Avatar
ScottXL
What I did was just take every fuse out and check them. That's the best way to do it, IMO.
jrrhd73must
Oct 2, 2015 09:17 PM
KingRando
Oct 2, 2015 08:06 AM
ChampInSD
Oct 2, 2015 04:55 AM
Sep 25, 2015 06:58 PM
