Check Engine Light and Engine Reving
Old Mar 16, 2008 | 06:06 PM
godfather181's Avatar
godfather181
Default Check Engine Light and Engine Reving
I have a 2001 v6 3.8 Liter (manual transmission) with the "Service Engine Soon" light on, and it's RPMs are now increasing on their own when I put it in neutral.
I was told the light indicated "Bank 1" "Cat converter not at efficiency", and that it was likely an O2 sensor gone bad. But upon getting under the car, we found it has 4 O2 sensors, and have no idea which one it is.
We were also told that the cause of the light and / or cause of the RPM increasing may not be O2 sensors at all, that it may be a loose vacuum line.
Anyone have any idea on what might be the cause of the engine light and the RPM increasing. I don't even know for sure if their related??
Thanks!
Old Mar 17, 2008 | 03:28 AM
MU71L4710N's Avatar
MU71L4710N
Default RE: Check Engine Light and Engine Reving
02 sensors have nothing to do with how the car runs. it just tells you that your cats (or 02 sensors) are screwed up. you can either replace your 02 sensors or just put mil elims on (30$ or make your own for 5 bucks) and that will get rid of that problem.
Old Mar 17, 2008 | 09:23 AM
brad281's Avatar
brad281
I had a problem with my egr valve on my 01. Sometimes car wouldn't start, or would quickly die when rpms dropped.
Old Mar 17, 2008 | 04:05 PM
godfather181
Sorry for the newbi-ness, but what's a mil elim??
Old Mar 17, 2008 | 04:39 PM
manuelm's Avatar
manuelm
u can check the o2 sensors w a ohm meter. u can get those at autozone or checkers. it will tell you what the meter should read on at the autozone website when you look up the sensor, and it tells u how to test it. i dont think that is causing your problem though. prob something to do w the emmisions on the car, maybe egr valve, pcv valve possibly.
Old Mar 17, 2008 | 04:51 PM
brad281's Avatar
brad281
Can you stop by an autozone and check which code your throwing? Egr's a common problem, unlikely, but maybe the iac?
djbigskrilla
Sep 20, 2022 01:04 AM
labudski
Aug 24, 2015 07:23 AM
microgt
Aug 20, 2015 07:12 AM
mweiland
Aug 13, 2015 05:11 PM
drumhedd2005
Aug 13, 2015 09:59 AM
