What fox weighs the least? Any experience?
Old Mar 24, 2008 | 09:25 PM
MustangMan628's Avatar
MustangMan628
Default What fox weighs the least? Any experience?
Alright, I have been looking for a good topic on this and haven't been able to find one, so I decided to make my own. My next project HAS to be an 87-93 Fox. Most likely an 89-93 Fox. I am looking at a $200 4 cyl auto notchback with an exceptional body and shot everything else. I've also seen some cheap verts kicking around. Although I have only ever owned hatchbacks. This is going to be my be all end all drag car and I want it as light as possible. Although I don't like verts, in the end it probably won't have a top on it. Just a cage. I don't particularly care about the factory wiring and computer and **** because I know most of it inside and out already and a lot will be replaced anyway. In fact, I highly doubt that I will even be able to run fuel injection efficiently in the end. I want to get started by mid summer after shopping around a bit and saving up a little cash. I know there are some die hard Fox guys on this site, and was just wondering if anyone had any experience with this topic. Again, I will say that I don't plan on having this car road legal and may never even register it. I just want the lightest Fox I can build. Hope to get some results, or at least get pointed in the right direction. Thanks.
Old Mar 24, 2008 | 09:39 PM
ryan1994mustang's Avatar
ryan1994mustang
Default RE: What fox weighs the least? Any experience?
im pretty sure the notch is going to be the lightest of them all, even if you take the vert top/motor out. the vert may weigh less at that point, but the amount of weight you are going to have to add to get the suspension as solid as a coupe is going to offset that weight difference.
Old Mar 24, 2008 | 10:05 PM
1991LX5.0's Avatar
1991LX5.0
despite how it may look verts actually weight much more. Because their is not top their has to be much more structure supports to stop twisting/to protect in a rollover. A 4cyl notch is by far the best way to go not only is it the lightest but the body is also the strongest, i have actually seen some hatchback cars that the quarter panels have wrinkled from hard launches
Old Mar 24, 2008 | 10:16 PM
MustangMan628
I plan on a fully welded cage, sub frame connectors, the whole nine yards. I'm not in any hurry to put this puppy on the road. I will eventually get it to not twist on launch. I really like the hatchbacks though. I have been trying to find a reliable factory curb weight web site, but haven't had much luck. A buddy of mine suggested taking my car down to a truck scale at the local dump, but I don't know how accurate that is. I think I posted this in the wrong spot though, I'm gonna try and move it to the 5.0 section. My bad.
Jan 21, 2016 01:30 PM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
RCS02v6
Sep 29, 2015 01:46 PM
Sep 23, 2015 01:28 PM
