Vehicle storage
Old Mar 26, 2008 | 10:22 AM
Gruntstanger's Avatar
Gruntstanger
Default Vehicle storage
Any advice on vehicle storage out there. I will have to store my car in the garage for 14 months and wanted to know thoughts on jack stands or not. Also should I lay a tarp down over the concrete floor. Thanks
Old Mar 26, 2008 | 10:44 AM
piperpilotduane's Avatar
piperpilotduane
Default RE: Vehicle storage
Jackstands will keep the tire from flat spotting!
Old Mar 26, 2008 | 10:57 AM
GreyStang's Avatar
GreyStang
For +1 year storage you'll want to add fuel stabilazer to the gas and fill the tank FULL to prevent condensation. And yes use jackstands to get the tires off the ground.
Is the garage weather tight?
Some would suggest removing the battery, others would suggest leaving the battery in and starting the car up about once per month for at LEAST 15 minutes. Personally I'd suggest pulling the battery out.
Change the oil before storage, perhaps flush the cooling system as well if that hasn't been done in a while.
Yada yada &a bunch of other to-do's
Old Mar 26, 2008 | 11:55 AM
Machmax777's Avatar
Machmax777
i would also but a box of baking soda in the floorboard and maybe in the trunk
Old Mar 26, 2008 | 01:02 PM
Riptide's Avatar
Riptide
What's the baking soda do?
Old Mar 26, 2008 | 01:39 PM
Ryan86272's Avatar
Ryan86272
ORIGINAL: Riptide
dont forgett the Ice Cream and Choc Syrup... Maybee a Cherry and Whip Creame.......
Im pretty sure Baking soda(like in a Refridgerator) will keep it smelling nice, No mold or bacteria? Maybee? Just a Flat out guess seems like a good idea..
Old Mar 26, 2008 | 01:50 PM
1367mustang's Avatar
1367mustang
Moth ***** on tarp under car. Bounce sheets inside and steel wool up both tail pipes.
Mice
Brian
Old Mar 26, 2008 | 02:38 PM
Machmax777's Avatar
Machmax777
yea the baking soda absorbs moisture and keeps that mildew smell out
Old Mar 26, 2008 | 04:10 PM
Gruntstanger
Right on for the advice, yeah I had heard about the sheets of bounce before with good results.
Old Mar 26, 2008 | 04:52 PM
ewgoetz's Avatar
ewgoetz
Coat your engine bay witha can of wd40 will cut down on rust. Probably wouldnt be a bad idea to spray around under the car as well if its gonna be on jack stands.
