electrical nightmare
Old Mar 26, 2008 | 09:03 PM
cueball's Avatar
cueball
Default electrical nightmare
i have an 88 lx that was recently broken into, the amature thieves destroyed all the lock cylinders and the ignition switch, they couldnt getit started. after finding this night mare i grabbed a screw driver and started the car. the next day i tried to start it and the car wouldnt even crank, the cluster wasnt turning on, the door chime wasnt goin off, the lights wernt working, nothing was working, i checked the battery, its ok, i bypassed the started solenoid its ok, i cant seem to hear the pump runing. could this be a ecm issue or something really simple.i would greatly appreciate any feedback on this issue.
Old Mar 27, 2008 | 02:02 PM
ewgoetz's Avatar
ewgoetz
Default RE: electrical nightmare
Check teh fuses in the engine bay and under the dash. You should have dash lights even if the ecm was toast. Might be your ignition switch if the fuses are ok.
Old Mar 27, 2008 | 07:11 PM
89MUSTANGCONVERTIBLE's Avatar
Replace your ignition switch. It not connecting a good groud source since its broken. Autozone has them instock
Old Mar 28, 2008 | 09:45 AM
lharville1's Avatar
lharville1
It is definately your ignition. Everything worked fine until it was destroyed by the break in, right?
LiquidDrink
Sep 29, 2015 10:06 AM
mrappe
Sep 26, 2015 10:16 AM
trashxtrash
Sep 20, 2015 10:49 PM
2015Ecoboost
Sep 17, 2015 01:48 PM
