Dyno tuning
Old Mar 31, 2008 | 11:19 AM
MustangMike2001's Avatar
MustangMike2001
Default Dyno tuning
Do you need to have a handheld programmer to get a dyno tune? I see that some places charge a lot less if you do have one. So do you have to purchace a tuner to get the car tuned or what?
Old Mar 31, 2008 | 11:43 AM
acascianelli's Avatar
acascianelli
Default RE: Dyno tuning
Yes...I think.
Old Mar 31, 2008 | 03:00 PM
MustangMike2001
Anybody know for sure?
Old Mar 31, 2008 | 03:37 PM
GreyStang's Avatar
GreyStang
I think the places that "charge more" are including the price of a tuner in the quote..
There isn't a lot of tuning adjustments available without a handheld tuner
Old Apr 1, 2008 | 07:31 PM
MooseStang88's Avatar
MooseStang88
From what i understand you have to have a tuner or a chip. I had a tuner before I went to the dyno. My mechanic told me that I should just get a chip instead, because you can do more.
Old Apr 1, 2008 | 07:45 PM
blstoff's Avatar
blstoff
yes . you need one . HH or chip . a chip is not better than a HH tuner . the same software is used to tune your car whether you use a HH or a chip . a HH has more options , if you get a HH you'll have on-device adjustments .
Old Apr 2, 2008 | 10:00 PM
ceracer33's Avatar
ceracer33
some places can just reflash ur factory computer and do not require u to purchase anything. u need to figure out who u want the car tuned by and talk to them about whether or not they are going to require u to have a programmer. if ur not dead set on getting a dyno tune, i suggest getting the sniper special forces software. it loads onto a computer and uses an interface box to reflash ur factory pcm. u read ur stock pcm, load it to the software, select ur mods from a drop down menu and it creates a tune for u. if ur not happy with the one it creates u can then make changes to the a/f ratio and timing urself. also allows u to turn off the rear 02's, egr, speed limiter, traction control and all that good stuff. u can tune for supercharged applications, nitrous, n/a, or turbo. its a very nice program, and at $389 is at a VERY reasonable price. i have it and love it.
Sixx
Oct 5, 2015 07:36 PM
Explosive
Oct 2, 2015 07:45 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
RCS02v6
Sep 29, 2015 01:46 PM
