Automotive Fluids Safety Cheat Sheet
Old Mar 31, 2008 | 06:13 PM
Troon2004's Avatar
Troon2004
Default Automotive Fluids Safety Cheat Sheet
Automotive Fluid Safety Cheat Sheet
We’ve met very few
car enthusiasts clued into the specifics of the fluids they use regularly. By referencing a selection of products’ Material Safety Data Sheet (MSDS), we’ve composed this quick overview to at least raise awareness. This information is meant to be a quick “first shot” for personal use and is generalized data. Some products may have specific ingredients with their own unique hazards, so don’t take the following as the last word. You can perform simple internet searches to find an MSDS for a specific products.
Disposal of all of these products is handled locally in different ways. Unless specified below, none of them are safe for emptying into the environment, including sewer systems via your shop toilet! Every city or county should have a waste management division or extension office that can direct you to the proper people to talk to.
Gasoline
Major Ingredients by Volume: Hexane and other isomers, toluene, xylene, octane
Severe Hazards: Obvious extreme flammability, especially fumes. Contains benzene and toluene which are a cancer (and potentially reproductive) hazard. Severe eye irritatant: Wash eyes with water for at least 15 minutes and seek medical attention if irritation continues. Prolonged contact with skin may cause moderate irritation - wash with soap and water thoroughly. Ingestion: Do NOT induce vomiting. Seek immediate medical attention.
General Usage Notes: Use in well ventilated areas only.
Storage Notes: Store in tightly closed containers in cool, dry, isolated and well ventilated area away from heat, sources of ignition and incompatible materials. After handling this product, wash hands before eating, drinking, smoking or using toilet facilities.
Coolant and Antifreeze
Major Ingredients by Volume: Ethylene Glycol
Severe Hazards: Ingestion or eye contact (much less severe than ingestion). Seek immediate medical attention if ingested.
General Usage Notes: For splashes or other contact with the skin, wash skin with soap and water thoroughly as soon as possible.
Storage Notes: Store in closed container. Sweet taste and smell of product can draw animals which will likely die from ingestion.
Brake Fluid
Major Ingredients by Volume: Glycol Ethers, various -ethylene glycols
Severe Hazards: Ingestion: Seek immediate medical attention if ingested. Lethal dose is only 4 ounces. Do NOT induce vomiting. If vomiting occurs spontaneously, keep head below hips to prevent aspiration of liquid into lungs. Eye contact: If eye contact is made, wash eyes for a full 30 minutes with water then seek further medical attention. Severe eye irritant.
Disposal: Kept uncontaminated, treat as oil for disposal. If contaminated with brake cleaner, etc, it is a hazardous material and should be disposed of differently. Check local laws.
Windshield Washer Fluid
Major Ingredients by Volume: Methanol (up to 35%)
Severe Hazards: Slight eye irritant: Wash thoroughly with water for 15 minutes. If ingested could cause blindness or fatality: Induce vomiting, then give two teaspoons of baking soda in a glass of water; call a physician. For skin contact, wash thoroughly with soap and water.
General Usage Notes: Methanol is corrosive to metals.
Automatic Transmission Fluid
Major Ingredients by Volume: Highly refined mineral oil, but varies
Severe Hazards: Generally no severe eye or skin irritation expected if exposed. If ingested in significant amounts, seek medical help as a precaution. You’re probably smart to flush your eyes or skin quite a bit if contact is made as some ATFs have additives in small amounts that are irritants.
General Usage Notes: None
Power Steering Fluid
Varies between similarities of Brake Fluid and Automatic Transmission Fluid.
Synthetic and “Dino” Motor/Gear Oil
Major Ingredients by Volume: Base oil, highly refined
[font="times new roman"]Severe Hazards: Nothing too severe here. Eye irritation: Flush with water for 15 minutes and seek medical help if irritation persists. Ingestion: large amounts = seek medical help, small amounts = may cause gastrointestinal irritation and/or diarrhea. In either case, do NOT induce vomiting unless instructed by a medical professional. Skin contact: Wash area thoroughly with soap and water. Remove and wash any affected clothing before reuse.
[font="times new roman"]General Usage Notes: Used engine oil may contain hazardous components which have the potential to cause skin cancer. Frequent or prolonged contact with all types and makes of used engine oil must therefore be avoided and a [URL=http://www.allfordmustangs.com/forums/2005-mustang-gt-tech/111423-automotive-fluid-safety-cheat-
Thunderball
15
Nov 22, 2015 11:49 PM
wraith777
Sep 28, 2015 10:49 AM
nmra1965
Other Professional Racing
Sep 26, 2015 10:46 AM
Sep 25, 2015 06:42 PM
