lower control arm bolt problem
Old Apr 6, 2008 | 09:53 PM
kriscribner's Avatar
kriscribner
Default lower control arm bolt problem
hey guys... im trying to put lowering springs in my 01 gt coupe... and i got the passenger side stock spring out fine... but the drivers side one seems to have a probelm.. when i try and unbolt the lower control arm from teh axle mount, the nut cam eoff fine.. then i started to pull the bolt out and at teh veryend out the tread sticking out on the nut side (facing outward) the whole rubber bushing seems to be spinning inside the control arm. its like the bolt is stuck to the metal guide it goes thru when it passes in the bushing... i dotn no how to can pull the bolt out! any suggestions??
Old Apr 6, 2008 | 11:43 PM
MustangMike2001's Avatar
MustangMike2001
Default RE: lower control arm bolt problem
Might help to jack up the rear to relieve pressure off the bolt and hit it with some lube.
Old Apr 7, 2008 | 10:31 AM
BowlerGT's Avatar
BowlerGT
This sounds so familiar since I just had the same problem. In my case trying to get it out resulted in a broken finger (trying to hit the bolt out and missed) and no matter how I jacked the rearend I couldnt move it. Now since I replaced mine with lakewoods I ended up taking a sawzall tomine control arm cutting it in half and was able to get it out then.
Old Apr 7, 2008 | 10:41 AM
ewgoetz's Avatar
ewgoetz
get a smaller diamiter bolt and push it throught using a small hammer to tap it out.
JonnyBlazeGT
Nov 3, 2015 01:10 AM
GimpyHSHS
Aug 29, 2015 06:30 PM
cedarmn
Aug 28, 2015 09:51 PM
Mobiusone stang
Aug 24, 2015 04:08 PM
inyadreems
Aug 21, 2015 09:10 AM
