Convertible window seal? HELP!!!!!!!!!!
Old Apr 29, 2008 | 07:12 PM
pbMaxLax44's Avatar
pbMaxLax44
Default Convertible window seal? HELP!!!!!!!!!!
So the window seal in between the window and the quarter window on my '00 vert is busted. I went to a shop and they took a look in the ford parts catalog and they said it comes on the quarter window so I'd need to get that replaced...but there is no effing way I'm paying $1000 for that. Anyone know of how I can get just the seal to put on? I've been calling junkyards also btw.
Old Apr 30, 2008 | 06:33 AM
GreyStang's Avatar
GreyStang
Default RE: Convertible window seal? HELP!!!!!!!!!!
Depends on how busted it is.. is the rubber part just ripped or is the metal part damaged too?
Maybe you can use glue to fix up the old one..
WTF $1000 for a replacement rear side glass?? [&:]
Old Apr 30, 2008 | 07:49 AM
onesickstang01's Avatar
onesickstang01
man id be calling up some slavage yards and seeing if they have your window. i just had to replace both door windows on my car and i got them both for 85 from junk yard. its worth a try. go to car-part.com and that will hook you up with most the yards in your area and you can search their inventory to see of they have your part
Old May 2, 2008 | 11:34 AM
pbMaxLax44's Avatar
pbMaxLax44
ORIGINAL: GreyStang
It's just the rubber part, the metal underneath is still perfectly fine. I could glue it because it's all still there just ripped. Lately I just haven't been touching the window because If I don't touch it, it stays fine when I push it back the way it's supposed to be.
ORIGINAL: onesickstang01
Thanks, that site helps a lot with finding the junk yards. =)
Old May 2, 2008 | 11:42 AM
pbMaxLax44's Avatar
pbMaxLax44
Another quick question, I found one from a salvage yard for $75 but it's off a '96 convertible. Will that fit? Mine is the 2000 model made earlier on in the year, with the older style interior. Because when I searched it asked if it was that older model or not and the '96 quarter window came up.
Old May 2, 2008 | 12:12 PM
GreyStang's Avatar
GreyStang
The salvage yard should be able to tell you if the window fits or not
zsmart
Convertible Tech
Feb 29, 2016 08:33 AM
GPR
Dec 16, 2015 12:21 PM
treesloth
Sep 28, 2015 07:03 AM
DreadPirateRoberts
Sep 26, 2015 02:11 PM
Demodulates
Sep 18, 2015 11:14 AM
