99 gt vert power window problem
Old May 2, 2008 | 06:48 PM
johnnyH's Avatar
johnnyH
Default 99 gt vert power window problem
currently on my 99 gt vert the power windows will not go up nor down. the front and the rear windows. like its recieving no power. since i didnt have an owners manual, i was wondering if someone on here could help me out and let me know where the power window fuse and the power window relay is located. i had this problem before, but when it does happen i wait a few minutes and it works again. any help would be greatly appreciated. thanks!
Old May 3, 2008 | 09:24 PM
ewgoetz's Avatar
ewgoetz
Default RE: 99 gt vert power window problem
Does the PS switch work? If it does than you might have a bad DS door switch. I don't think there are relays for the power windows. Sayin it may be a bad DS switch cause u said you had a issue with it before.
Old May 3, 2008 | 11:29 PM
ryan1994mustang's Avatar
ryan1994mustang
yeah, check the passenger side switch and see if that window will go down with that switch. if it will then its more than likely your drivers side switch panel.
Old May 5, 2008 | 11:51 AM
johnnyH's Avatar
johnnyH
none of the windows work. either door switches work. so maybe a fuse? i checked all the fuses on the driver side and all of them are still good. none are burnt. so i dont know where to look from here.
Old May 6, 2008 | 04:07 PM
ewgoetz's Avatar
ewgoetz
Do you have a alarm on it? Best thing next to do is take the door apart and check if you are getting power to teh switch.
Old May 8, 2008 | 09:54 PM
onesickstang01's Avatar
onesickstang01
i had this problem on my 01 several times. neer found out what i t was but its pretty common i guess. what i always ended up doing was holding the buttons down and then slamming the door shut(while still holding them) it made them work every time
NorthAmericanTuning
Nov 9, 2016 11:45 AM
NorthAmericanTuning
Mar 18, 2016 11:21 AM
JonnyBlazeGT
Nov 3, 2015 01:10 AM
YoungStangsMan
Sep 5, 2015 07:01 PM
movielover40
Aug 27, 2015 10:13 PM
