rear tire size
Old May 5, 2008 | 08:36 AM
dh04 red gt's Avatar
dh04 red gt
Default rear tire size
Right now I have the stock tire size 245-45-17 on a stock rim for a 2004 gt can I go to a 255 or 275 tire on the same rim. I like the rims that came with the car. just want wider tires in the rear for more traction.
Old May 5, 2008 | 08:40 AM
92stangerang's Avatar
92stangerang
Default RE: rear tire size
275s fit without any problems.
Old May 5, 2008 | 09:39 AM
rwdfan's Avatar
rwdfan
I would think there would be some unsafe bulging. I have 18X10's with 275s on them and my 17X9's have 245s on them. Just my 2 cents. [sm=badidea.gif]
Old May 6, 2008 | 12:43 AM
P.S.I.cho's Avatar
P.S.I.cho
you can use a 255 i probly wouldnt use a 275, if you go to a tire shop they can tell you what they will and wont do safely tho
Old May 7, 2008 | 02:02 AM
rossn's Avatar
rossn
I was also told 255 safely. Some shops may allow slightly larger.
Old May 7, 2008 | 10:13 PM
Stang9946's Avatar
Stang9946
275 will fit fine. If you're really uncomfortable about it then put on 265/40s!!
Old May 8, 2008 | 06:21 PM
Mjaga251's Avatar
Mjaga251
I bought the car with 275's and am still running them..no problems.
Old May 8, 2008 | 07:27 PM
sem76's Avatar
sem76
My friend has a 2000 stang and has 275s on his stock wheels. He says they fit fine but bulge a little which he thinks it causes his car to float a little in the rear if that makes sense. He doesn't seem to get good traction because of that. He had more traction with his 245s.
Old May 8, 2008 | 10:53 PM
ronsfun96gt's Avatar
ronsfun96gt
check some tire places on the internet such as tire rack. They can tell you what tires will work with a given wheel size.
Old May 9, 2008 | 12:27 AM
Stang9946's Avatar
Stang9946
ORIGINAL: ronsfun96gt
They will say that a 255/45 is the best fit for a 17x8 wheel. But a 275/40 is the biggest you can put on an 8in wheel. I went from 245 to 275 and didn't notice any "floating" or loss of control. If anything, I gained a bit of traction.
