Shifting becoming a concern
Old May 5, 2008 | 09:40 PM
94gtbuilder's Avatar
94gtbuilder
Default Shifting becoming a concern
I am having an incredibly difficult time shifting as of late in my stang. I read a few similar posts about the situation and have come to a few conclusions as to what the problem may be. The guy who had it before me put a high friction clutch in it, and i believe it's warped the quadrant or something, and has the clutch all out of adjustment. Does this seem plausible? If so, steeda makes this clutch adjuster kit (http://www.steeda.com/products/clutch_adjuster_kits.php). Would this solve my problem? I'm pretty sure the shifter is stock as well as the cable and my car has almost 200,000 miles. I also read something about a TO bearing which I'm not familiar with. I really dont want to destroy my transmission. I plan on getting a tri-ax soon, would that have a new TO bearing? I really dont know much about transmissions. Thanks for the help.
Old May 6, 2008 | 12:37 AM
P.S.I.cho's Avatar
P.S.I.cho
Default RE: Shifting becoming a concern
what exactly is it doing, is the clutch feeling stiffer, is it grabbing at a different pedal height or is it grinding while you try to shift? at 200k miles if the transmission hasnt been rebuilt yet this would the that mark where the synchros inside the trans are starting to go out, if this is the case it will grind while shifting gears, and if this is happening best to get it rebuilt ASAP and save money the longer u wait the more expensive the rebuild will be as more parts will fail with metal debris in the transmission
Old May 6, 2008 | 12:49 AM
94gtbuilder
I kinda doubt it's the original tranny but i dont know. All i know is it's really hard to shift into gear. I dont seem to be having much trouble with the clutch itself, but I really dont know??? The car doesnt even have to be moving for this problem to occur. It even happens when I go from neutral to 1st. It just doesnt want to engage!
Old May 6, 2008 | 11:48 AM
Jfsram's Avatar
Jfsram
Sounds like the clutch is not disengaging completely. So the disc is spinning and you are forcing your synchronizer to stop the disc. Hence the high resistance on your shifter.
Sometimes the same will occur if the pilot bearing/bushing is frozen to the input shaft.
Can you upshift ok. Or will it easily slip into gear with the engine off?
Old May 6, 2008 | 11:58 AM
94gtbuilder
It seems to go into gear ok with the engine off. How difficult is it to change the syncros? or the pilot bearing?
Old May 6, 2008 | 08:24 PM
94gtbuilder
OK went out and checked it out a little bit this afternoon. The clutch is way out of alignment, soo it's not the sycros or a bearing most likely. Should I get the Steeda clutch kit (http://www.steeda.com/products/clutch_adjuster_kits.php) because I'll probably damage the quadrant if it isnt already serevely damaged sooner or later. Does anyone know of anything cheaper maybe that will be of good quality?
Old May 7, 2008 | 12:06 PM
P.S.I.cho's Avatar
P.S.I.cho
usually if these clutches are out of aligntment the quadrent has failed since the stock one is plastic, you may not need the entire adjustable clutch kit but i really like my adjustable cable, but if you dont want to spend the money try getting a new quadrent
Old May 7, 2008 | 01:05 PM
94gtbuilder
I think I'll just get the entire kit. The guy before me probably never changed it soo it probably wouldnt hurt to get a new clutch cable and the firewall adjuster is just conveinent in my opinion, and really only like 15 bucks compared to if u buy everything seperate.
Thunderball
15
Nov 22, 2015 11:49 PM
chrisdbassplayer
Oct 13, 2015 06:53 PM
UrS4
Oct 3, 2015 06:23 AM
Explosive
Oct 2, 2015 07:45 AM
Teddi
Sep 29, 2015 12:24 PM
