Need Help bad!!!! From you experts
Old Apr 22, 2005 | 02:53 PM
dam123's Avatar
dam123
Default Need Help bad!!!! From you experts
A buddy of mine has Ls1 thats the first problem, just kidding --- He just put on a underdrive pulley and at 5500 rpm it noses over floats valves no power. he has up graded the alternator. Everything was fine until the underdrive pulley would pull all the way up to 6000 rpm Any ideas
Old Apr 22, 2005 | 03:02 PM
JD1969's Avatar
JD1969
Pro. B.S. caller outer
Default RE: Need Help bad!!!! From you experts
Why do you think it is valve float? Also try changing back to the orig. pulley that way you make sure it is not caused by somthing else. That would be my first step. Also try posting this on LS1tech.com you will get alot more LS1 guys looking at it over there.
Old Apr 22, 2005 | 03:14 PM
dam123's Avatar
dam123
He has tries to post else where but no one seems to know. Just giving it a shot over here thats all. Do you have any??????????
Old Apr 22, 2005 | 03:26 PM
JD1969's Avatar
JD1969
Yes try puting the stock pulley back on and see if the problem is the same, then come back to me and I will see what I can find out for you.
Old Apr 22, 2005 | 06:16 PM
vfast's Avatar
vfast
I ♥ Acer
don't think it's pulley related unless it's drive a cam which it isn't......he'll need some new valve springs now
Old Apr 24, 2005 | 02:46 PM
dam123's Avatar
dam123
I just talked to my buddy and he said when he puts the clutch in it will go to 6000 rpm with no problem untlil he puts a load on it then the problem occurs.
Dathan
Oct 5, 2015 05:52 AM
KingRando
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
UrS4
Sep 30, 2015 10:13 AM
