vacuum help
Old May 10, 2008 | 05:43 PM
sYckmYnded's Avatar
sYckmYnded
I ♥ Acer
Default vacuum help
anyone have a vacuum diagram? so i can get my car to stay running?? put a new intake on it and now it surges up to about 4k then drops down and dies, will not stay running, im hoping its just vacuum, any thoughts?
Old May 10, 2008 | 05:50 PM
ALMOST STOCK's Avatar
ALMOST STOCK
Default RE: vacuum help
Vacuum Diagrams!
http://www.veryuseful.com/mustang/tech/engine/
Old May 10, 2008 | 06:03 PM
sYckmYnded's Avatar
sYckmYnded
I ♥ Acer
thats awsome man thanks a ton, only problem is, im TOTTALY lost, i bypassed the vac tree since all the a/c heat controls have been replaced by gauges ran the brake booster strait off the 1 of the vac lines from the upper intake then ran the pcv valve hose off another then, i have this vac line coming up off the transmission it seems so i hooked that up, what am i missing that would make it jump to 4k then drop down and die?[:@]
Old May 10, 2008 | 06:08 PM
ALMOST STOCK
Where do you have your Charcoal Cannister Vacuum hooked, or do you have a Charcoal Cannister?
Old May 10, 2008 | 06:16 PM
sYckmYnded's Avatar
sYckmYnded
I ♥ Acer
none
Old May 10, 2008 | 06:24 PM
ALMOST STOCK
Are you saying you need torev to 4K and then if wants to die?
Does it backfire also?
Old May 10, 2008 | 06:28 PM
sYckmYnded's Avatar
sYckmYnded
I ♥ Acer
no as soon as i start it up, it jumps to 4k by it self then drops and dies if i feather the gas it will run and what sounds like a back fire through the upper intake
Old May 10, 2008 | 06:37 PM
ALMOST STOCK
Itdefinitely sound like you have a vacuum leak because mine did the same thing!
1st time was the hose from the Charcoal Canister, 2nd time was the PVC valve came out of the grommet and both time I had the same problem you're talking about
Here are a few more vacuum diagrams thatI have that may or may not help?
Sorry.... but it's the best that I can do for you, other than saying you'll need to find that leak .
Old May 10, 2008 | 06:41 PM
sYckmYnded's Avatar
sYckmYnded
I ♥ Acer
ok man thanks for all the help imma go check the pcv it might have poped out
mrtrodonet
Sep 19, 2020 03:12 PM
baddog671
Jul 26, 2016 01:20 PM
Ipaman
Sep 22, 2015 07:01 AM
SteelerNation82
Sep 16, 2015 07:11 AM
TfcCDR
Sep 14, 2015 12:08 PM
