Whats shimmed?
Old Apr 23, 2005 | 08:23 PM
Dbeck002's Avatar
Dbeck002
I ♥ Acer
Default Whats shimmed?
what do they mean when referring to heads as 'shimmed for a decked block'? thanks.
Old Apr 24, 2005 | 11:03 AM
FoxGT's Avatar
FoxGT
Default RE: Whats shimmed?
Using something to get the valves back up to the height they were at before any work was done to the heads. Usually a thicker head gasket is used.
Old Apr 24, 2005 | 12:48 PM
C/Note's Avatar
C/Note
I ♥ Acer
never heard of that ,down this way..?
Old Apr 24, 2005 | 01:00 PM
FoxGT's Avatar
FoxGT
Tis to get valve clearance back up to OEM status if you've had your block/heads machined, so you don't break anything.
Old Apr 24, 2005 | 02:01 PM
Magiarn71's Avatar
Magiarn71
Why would you deck a block and then use a thicker head gasket? Wouldn't the clearance be the same because the piston needs to be modified to be flush with the block at top? I figured that they were shimming the rockers to use the same pushrod, but I don't know. If you shave off the heads I can see that, but this is for a decked block.
Old Apr 24, 2005 | 03:37 PM
FoxGT's Avatar
FoxGT
I guess it depends on how much it is machined.
Old Apr 25, 2005 | 02:03 PM
roundman's Avatar
roundman
never heard that term used before so I don't have a clue what it really means.
it might be referring to the machining done to the intake manifold when the block is decked a lot to keep the intake ports aligned but that is just a guess on my part.
Old Apr 26, 2005 | 02:06 AM
Magiarn71's Avatar
Magiarn71
Where did you see that Dbeck? Now I'm really curious.
Old Apr 26, 2005 | 02:30 AM
Dbeck002's Avatar
Dbeck002
I ♥ Acer
I saw it on ebay, some guy is selling edelbrock heads. ill get the link hold on.
Old Apr 26, 2005 | 02:31 AM
Dbeck002's Avatar
Dbeck002
I ♥ Acer
http://cgi.ebay.com/ebaymotors/ws/eB...category=46098
