Turning over an engine Manually
Old May 18, 2008 | 04:10 PM
sincere0113's Avatar
sincere0113
Default Turning over an engine Manually
How can I use the starter to turn the engine. My engine is pulled out and I want to use the starter and battery to turn the engine. How do I do this?
Old May 18, 2008 | 04:26 PM
mikehands's Avatar
mikehands
Default RE: Turning over an engine Manually
If the starter is installed, just ground the battery to the engine and tap the solenoid connection with the positive lead.
Old May 18, 2008 | 09:12 PM
golden_eye's Avatar
golden_eye
If the engine is already out why don't you just use a breaker bar and socket on the crankshaft bolt? Doesn't take that much effort and it's probably safer than tapping bare electrical leads together.
Old May 18, 2008 | 10:59 PM
Jfsram's Avatar
Jfsram
You will need to install the bellhousing, flywheel and starter.
But why must you turn it with the starter if it's out of the car?
Old May 20, 2008 | 07:42 PM
sincere0113
right now i have the engine assembled, no plugs in, the torque converter is attached, the flywheel as well as bell housing I need to get two nuts on the torque converter, but i cant reach it unless i turn the engine over. I can't do it using a breaker bar, I was thinking of using the starter to do it. How can I do it, when I attach the starter directly to the battery it just sparks, no turn. Starter is new. Do I need to include the solenoid?
Old May 20, 2008 | 11:15 PM
1991LX5.0's Avatar
1991LX5.0
i still dont understand why cant you turn the motor over by hand?
djbigskrilla
Sep 20, 2022 01:04 AM
ShaneB26154
35
Mar 4, 2021 04:05 AM
KEM Motorworks
Aug 14, 2015 10:13 PM
drumhedd2005
Aug 13, 2015 09:59 AM
yurizx6r
Aug 11, 2015 07:50 AM
