AOD can hold ?
Old Apr 25, 2005 | 11:30 PM
92BOOSTED's Avatar
92BOOSTED
Default AOD can hold ?
With the mods that you see below, will this trans with a stall and a shift kit hold up?
What will a near stock aod tranny hold for power, as im thinking of swapping the T-5 out for an auto.
Rye
Old Apr 26, 2005 | 12:57 AM
luckythirteen13's Avatar
luckythirteen13
Default RE: AOD can hold ?
well if you get a standard ford aod it wont last long. id get one made specific for your application. im sure roundman has the link you need
Old Apr 26, 2005 | 08:25 PM
roundman's Avatar
roundman
don't really know the max stock rating for an AOD, but they were made to handle the 300 ft-lb torque the stock 5.0 engine makes and you're looking at an additional 100 ft-lb, so I would think an upgrade of the internal parts would be wise. The weak link in the AOD is the hollow input shaft but you can get solid ones to replace it but you will lose the lock-up feature with the torque converter.
check out www.lentechautomatics.com to see what they have to say
6bangr
Feb 15, 2016 07:40 AM
Oct 7, 2015 07:02 PM
Ryan Fitzpatrick
Sep 14, 2015 02:21 AM
mdj89
Sep 6, 2015 11:08 PM
