For those who do maintenance
Old Jun 8, 2008 | 10:00 AM
SnakeCarDriver's Avatar
SnakeCarDriver
Default For those who do maintenance
My apartment complex will not allow car maintenance to be done in the parking lots.
Any good ideas where to take the car to work on it myself?
Secondly, where is the rear jack point for the rear end of a 98 mustang cobra.
I'm trying to change my fuel filter. In the past, when Iwas in the Navy I could put it on a lift at the hobby shop on base. Now, I am finding it harder and harder to work on the car with the facillitesgone!!
Old Jun 8, 2008 | 10:08 AM
GreyStang's Avatar
GreyStang
Default RE: For those who do maintenance
Yea that sux most apartment comples parking lots don't want people crawling around their cars working on them. Next best thing would be go to a buddies garage. Better still if a buddy has a garage but no mech skills you can "thank" the guy by looking over his car while your there.
The jacking point is usually just in front of the rear tire. There should be a small notch in the body that matches the jacks notch
Old Jun 8, 2008 | 10:10 AM
USMC1775's Avatar
USMC1775
You should be able to change the fuel filter without a jack, but if not, I always put a peice of carpet on my jack and jackstands then lift the axle and support each side of it with the stands
Old Jun 8, 2008 | 10:14 AM
SnakeCarDriver
ok so if i jack using the rear wheel points i would need two jacks??
Old Jun 8, 2008 | 10:23 AM
USMC1775's Avatar
USMC1775
What youre looking for if you dont use the axle is the part of exposed frame as a jacking point. If you jack anywhere but there or the axle, youre risking all your car's weight on thin thin metal.
To answer your question, you should always use jackstands while under a car. That equates to bad news if not.
If you jack it from the frame vs. the axle, youre going to have to jack it for a bit longer in order to get the stands underneath
Old Jun 8, 2008 | 10:47 AM
SnakeCarDriver
Thank you! I guess I'll lift one side (where the filter is)and put it on a stand and get under there and do my thing.
These as prices are crazy recently. Luckily I have found that I can save a bit from shifting from 2nd right into 4th and save some engine strain.
Old Jun 8, 2008 | 04:03 PM
945LSTANG's Avatar
945LSTANG
jack it up with the jack under the differential. then put a jack stand on each side.
like this. (not me or my car. found this pic.)
Old Jun 16, 2008 | 03:05 AM
am2slim69's Avatar
am2slim69
the parking lot at autozone. that's what i do. and if you need something the store is right there. lol
Old Jun 16, 2008 | 08:23 PM
Jfsram's Avatar
Jfsram
Name your location. I'm sure there is a Mustang enthuasiast in the area willing to help out for a small fee.
dubarado
Dec 23, 2015 01:16 PM
piotrek53
Oct 13, 2015 06:54 PM
Sep 25, 2015 06:42 PM
motown girl
Aug 28, 2015 08:21 AM
Nexuia
Aug 25, 2015 04:06 PM
