blinker doesn't blink
Old Jun 11, 2008 | 05:13 PM
96VegasMustang's Avatar
96VegasMustang
Default RE: blinker doesn't blink
Ya know, if you have a problem with newbies on the boards, why don't you start a petition to get us all banned? Other than that? Ignore us.
Old Jun 11, 2008 | 05:50 PM
02TorchRedGT's Avatar
02TorchRedGT
Do you hazards work? If a blinker light dont blink but lights then it normally is the bulb or the flasher.
Old Jun 11, 2008 | 07:14 PM
ExtrmZ's Avatar
ExtrmZ
the hazards flash just fine..
Old Jun 12, 2008 | 10:38 PM
ExtrmZ's Avatar
ExtrmZ
still nothing.. any ideas?
Old Jun 15, 2008 | 09:18 PM
ExtrmZ's Avatar
ExtrmZ
TTT
Old Jun 16, 2008 | 01:23 PM
benhatch1's Avatar
benhatch1
Just had this problem. Had to replace the wire connecting to the bulb
Old Jun 17, 2008 | 02:56 AM
Uncletom_usn's Avatar
Uncletom_usn
I have a 1983 GT and am having the same problem. My left signal is low on blinker fluid too, I guess. All bulbs are good, hazards work, switched the silinoid, I even replaced the gound wire. I'm about ready to pull the gauges and find out if that tron looking circit board paper has a break in it.
Just as clueless, same problem.
-Uncletom
Old Jun 17, 2008 | 11:00 AM
ExtrmZ's Avatar
ExtrmZ
where does the wire going to the bulb hook to? why would that make a difference? the blinkers turn on.. just dont flash.. that doesn't seem like it would help them to flash..
Old Jun 18, 2008 | 08:01 PM
88_LX's Avatar
88_LX
get the turn signal switch tested.. or just go to a junkyard and get another one, its in the steering column take off the plastic shroud that behind the steering wheel and you'll be able to get it out, had the same problem )along with some other problems)on my 88 and it was perfect afterwards
Old Jul 9, 2008 | 04:55 PM
ExtrmZ's Avatar
ExtrmZ
sorry i had to bring this back up.. still having problems with it
ORIGINAL: 88_LX
my turn signals do turn on, but just dont flash... would someone do me a favor and take a pic of where their flasher is located, and of their fuse box? Is the flasher on the front of the fuse box, i know the hazard flasher is on the back, but it looks like there might be one on the front...
