1986 GT starting problems
Old Apr 30, 2005 | 02:13 PM
Nancy's Avatar
Nancy
Default 1986 GT starting problems
I have a 1986 Mustang GT automatic with 96,000 miles on it. I have a problem with hot starting. It starts fine cold but if I drive it and then stop and do errends somewhere the enging cranks very slowly. Usually after about 3 tries it t will start.
I have had the starter replaced 3 times.
Any hints?
Old Apr 30, 2005 | 03:09 PM
hunterzach_02's Avatar
hunterzach_02
Default RE: 1986 GT starting problems
sounds like starter to me. I have had that problem several times, but in different cars. You may also want to try the solenoid and wires (power and ground). Possibly a keyswitch, but I dont really think it is this.
Old Apr 30, 2005 | 04:17 PM
C/Note's Avatar
C/Note
I ♥ Acer
ORIGINAL: Nancy
Any hints?
you got the ford mini starter ,,how does your cables look ..bigger is better...
Old Apr 30, 2005 | 06:24 PM
TRL12087's Avatar
TRL12087
i had a similar problem with my 86, i had messed with the charging system for a while with no solution. all i did was change my battery cables and now its fine
Old Apr 30, 2005 | 06:28 PM
GreyStang's Avatar
GreyStang
Stock exhaust system on that car?
Any heat shields missing?
Sounds like you're overheating the starter(s), probably by exhaust heat.
djbigskrilla
Sep 20, 2022 01:04 AM
jjwinel78
Aug 17, 2015 03:34 PM
cvarner131
Aug 17, 2015 07:38 AM
KEM Motorworks
Aug 14, 2015 10:13 PM
Pain.
Aug 7, 2015 10:48 PM
