can someone help me
Old Jun 18, 2008 | 08:01 PM
shawnasmustang96's Avatar
shawnasmustang96
Default can someone help me
I have a 96 mustang gt 4.6 stick shift and it is getting hard to put into gear, and it wont downshift into 3rd from 4th gear. can someone tell me if something is going out or what?
Old Jun 18, 2008 | 08:56 PM
akp20032004's Avatar
akp20032004
Default RE: can someone help me
When you push the clutch does it squeal at all or does it make noises when it's not pressed in at all?
Old Jun 18, 2008 | 10:16 PM
mustangcat's Avatar
mustangcat
Deputy CatDog - To Purr'tect and Explode
Are you new to driving a stick? Have you gotten the friction point down on it?
Sounds like it could be you need a new clutch.
Old Jun 19, 2008 | 04:17 PM
shawnasmustang96
the clutch doesnt make noise, just had the ford dealer put a new clutch in it a couple months ago, cost 1,600.00. worked fine for a while then just started getting hard to put in gear.
Old Jun 19, 2008 | 06:36 PM
akp20032004
ORIGINAL: shawnasmustang96
HOLY F#@!
Shops will do it for about 400 or so.
Old Jun 19, 2008 | 10:31 PM
foru2nv4's Avatar
foru2nv4
try removing the floor mat. I have a racing clutch in mine and its hard to put in gear if the floor mat is there or even shift to any other gear. The clutch engages less than an inch off the floor so with the floor mat there its to thick for me to push all the way down to the floor for neutral.
Old Jul 11, 2008 | 12:11 PM
shawnasmustang96
I found out what was wrong with my car, its the clutch rod and ball. thanks for your help everyone.
