shifting in an automatic
Old Jun 22, 2008 | 04:36 PM
turbomustang18's Avatar
turbomustang18
Default shifting in an automatic
I have an automaticgt which i wish i didn't. i would like to get a manual transmission put in but i do not have $4000-$5000. Will it damage my transmission if i shift in my automatic? I usually go up to about 5 rpm in 1st then go to about 4 rpm in 2nd. then i just have to go to drive.
Old Jun 22, 2008 | 05:31 PM
GreyStang's Avatar
GreyStang
Default RE: shifting in an automatic
It won't help anything to manually shift your auto tranny
Old Jun 22, 2008 | 05:47 PM
05 Cayuse's Avatar
05 Cayuse
Say What? It won't hurt the auto to manually shift it. Have you ever noticed the auto-shifters on many new cars? I shift my 05 Vert manually all the time at the track (open-track events) to keep it from shifting too soon going through the corners.
Old Jun 22, 2008 | 05:55 PM
GreyStang's Avatar
GreyStang
Have you done ET runs comparing one where you manually shift VS letting the car shift? What kinda difference have you seen on timeslips?
Old Jun 22, 2008 | 05:56 PM
stealth_GT's Avatar
stealth_GT
you can to make it feel more torquey or for low roll racing..the thing is,1st and 2nd are the most powerful when shifting and 3rd is more of a passing highway gear.I have left it in 1st for a roll upwards of 30mph hitting redline then upshifting to D to get a nice jump,or from a higher roll I have used 2nd (2/D)with favorable results.3rd seems to lag in terms of building up speed so upshifting to D feels alot quicker.3rd on the highway is perfect for me when I need to pass,2nd is for merging and 1 is just to have fun in lol.
From a deadstop it seems like just leaving it in D,power braking to 2k seems to be the best bet for acceleration.
I don't think it'll hurt the tranny but it does build up heat I bet.Just avoid doing obviously dumb things and it should be okay lol.
Old Jun 23, 2008 | 12:01 AM
briansgonnawin's Avatar
briansgonnawin
If you going to be off roading and going up a hill, declining, doing a burnout, its better to drop it into 1st and 2nd manually if you really care.
When you engage into 1st and 2nd manually on a auto, it engages a secondary clutch in the tranny, i think in fords, it only has the secondary clutch in the 1st, but technically better for the tranny that way in certain conditions.
Old Jun 23, 2008 | 09:48 AM
mustangcat's Avatar
mustangcat
Deputy CatDog - To Purr'tect and Explode
If your racing; let your car do the shifting.
If you feel the need to Shift your Auto, it's Ok to it every once in a while, but if you do it often I'd suggest buying a trans cooler.
Like GrayStang said, it's faster to let the car shift itself.
Old Jun 23, 2008 | 03:27 PM
stealth_GT's Avatar
stealth_GT
http://www.levelten.com/hydrosystem_us.htm
Thunderball
15
Nov 22, 2015 11:49 PM
Explosive
Oct 2, 2015 07:45 AM
guitarman376
Sep 30, 2015 05:54 PM
wraith777
Sep 28, 2015 10:49 AM
