supercharger
Old Jun 28, 2008 | 02:33 PM
james.e.mcarter's Avatar
james.e.mcarter
Default supercharger
i am putting a supercharger (top mount belt driven) on my 1998 ford mustang gt conv. i no that i have to get a newmass air flowsensor, bigger injectors (looking at blue demon 42lb.), i have the manifold,coil packs andmsd ignition. i wanna no what other mods i should get that would accomodate the supercharger? or anymore mods that are cheap with a lot of outcome
Old Jun 28, 2008 | 02:39 PM
NoGo95GT's Avatar
NoGo95GT
Default RE: supercharger
You seem to be on the right track. The injectors and ignition sound find. You will need a 255lph fuel pump at least and also spark plkugs that are one heat range colder gapped to 0.32. If you want to increase performanceget a smaller crank pulley and an AFM PowerPipe. Of course your car will need a professional tune period.
Old Jun 28, 2008 | 04:20 PM
OnyxCobra's Avatar
OnyxCobra
255lph fuel pump and throttle body were the two things that came to mind.
Old Jul 1, 2008 | 11:49 AM
Hawktk421's Avatar
Hawktk421
I know this is a far shot but, My brother just bought a 1990 supercharged T-BirdandI noticed that ithad a 3.8L just like my Mustang Convervible. I was wonderingif I track one down in a junk yard and strap it on my '99 v-6Mustanginstead of dropping 4 grand on noe that might fit right. And if it would work what would I need to adapt it?
Old Jul 1, 2008 | 12:43 PM
LilRoush's Avatar
LilRoush
For the 3.8L question - the M90 will NOT fit the newer 99-04 3.8L cars do to the newer style heads. You can use the M112 from the Cobra though. Go poke around the V6 section for more info. $2800 for the set up.
ORIGINAL: NoGo95GT
I think you mean LARGER crank pulley. A smaller one would slow the blower down, resulting in a loss of power.
Old Jul 1, 2008 | 01:36 PM
NoGo95GT's Avatar
NoGo95GT
You're right, I was thinking of the supercharger pulley, in which caseyou would want a smaller one and a larger crank pulley. Thanks for the correction Lil
Old Jul 1, 2008 | 05:55 PM
LilRoush's Avatar
LilRoush
No problem - just checking. I've seen some guys swear up and down an underdrive crank pulley will free up hp on supercharged applications just like with N/A use.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
col2560
Sep 25, 2015 08:59 PM
