obd 2 port
Old Jul 15, 2008 | 09:31 AM
bullet281s's Avatar
bullet281s
Default obd 2 port
so i plugged my sct xcal 2 in and got nothing. then i plugged a regular snap on scanner in and that came right on.. i tried my tuner on anothe rcar just to see if it turned on and it did so i know its not my tuner... i used a tester on each of the pins to see which ones are the power pins on my obd2 port and one got one... if you know which pins are suppose to be power pins can u please let me know. and also if there is a fuse to check please let me know
Old Jul 15, 2008 | 02:59 PM
bullet281s's Avatar
bullet281s
Default RE: obd 2 port
does anyone know?
Old Jul 15, 2008 | 06:18 PM
mestit3's Avatar
mestit3
does your cigarette lighter work? when i do check engine lights anditwont work 9/10 its the cig lighter because usually they run off the same fuse.
Old Jul 15, 2008 | 06:59 PM
HaneyMotorsport.Com's Avatar
HaneyMotorsport.Com
Banned
^^ +1 ^^ The cig lighter and OBD port are on the circuit. Check and see if the cig works. If not ,replace the fuse.
Casey
Old Jul 16, 2008 | 05:40 AM
bullet281s's Avatar
bullet281s
thanks is there anything else it could be?
GimpyHSHS
19
Dec 19, 2023 01:12 PM
BOB ROME
Jul 26, 2023 01:54 PM
Dokilar
15
Oct 16, 2015 08:13 PM
Urambo Tauro
Oct 5, 2015 09:37 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
