Engine swap help
Old Jul 21, 2008 | 10:34 PM
dirtracer2a's Avatar
dirtracer2a
Default Engine swap help
Im looking at buy a 1991 Mustang from a buddy. It has the 2.3 engine with a 5 speed. I will drive it as is for now but plan on one day in the near future (if I buy it) putting in a 289, 351 windsor,or a 429. How hard is the engine swap in these cars and is there anywhere you can buy a kit to do the swap? What all needs changed?Any info would be great. Thanks
Old Jul 21, 2008 | 11:42 PM
92stangerang's Avatar
92stangerang
Default RE: Engine swap help
it sounds like your going to go carbed which is way easier. i would go 351 or 429. rule out the 289. it was a great motor but still. i know with the 351w you need the following...
1. motor mounts 302 and 351w are the same block.
2.double hump trans crossmember.
3. oil pan depending on where the 351w came from.if it came from a truck youll be good.
4. swap headers.shorts or longs its up to you and the wallet.
off the top thats all i can think of.
what tranny are you going to run?
5. 8.8 rearend wouldn't hurt but you can rock the 7.5 till it breaks.
Old Jul 22, 2008 | 02:44 PM
dirtracer2a
If I buy it and do the swap Ill put in a C-6 tranny and a 9" rearend. Doesnt sound like it should be to hard and I have a bunch of windsor parts so I might just buy it and try it. Thanks
Old Aug 1, 2008 | 07:23 PM
1992foxstang's Avatar
1992foxstang
you have just helped me tremendously as i am doing the same swap. but i'm keeping the factory t5 just changing the bellhousing. the motor is out of a van will i need to change the oil pan? and do i still have to change tranny mount?
Granatelli Sales
Jan 20, 2020 12:34 AM
Nick Oliver
Oct 17, 2018 04:22 AM
97SN95GT
Sep 13, 2015 09:45 PM
mdj89
Sep 6, 2015 11:08 PM
zachary1988
Sep 4, 2015 03:04 PM
