IS THERE A CHIP ?
Old Jul 25, 2008 | 06:47 PM
2000 G.T.'s Avatar
2000 G.T.
Default IS THERE A CHIP ?
SOMEONE SAID THAT WHEN I START MY CAR AND THE GAUGES GO FROM ZERO TO PEGGED AND BACK TO NORMAL THAT I MAY HAVE ACHIP IN THE CAR ALREADY. WHAT IS THE BEST WAY TO FIND OUT?
Old Jul 26, 2008 | 02:33 PM
92stangerang's Avatar
92stangerang
Default RE: IS THERE A CHIP ?
pull your carpet up on the passenger side and look at the side of the ecu.
Old Jul 27, 2008 | 01:39 PM
2000 G.T.'s Avatar
2000 G.T.
ONCE I PULL THE ECU WILL IT BE OBVIOUS THAT I HAVE A CHIP?
[IMG]local://upfiles/92494/D68440D4799F43E9B8C0632854FA68A5.jpg[/IMG]
[IMG]local://upfiles/92494/AACBBFB0F5C74A589BEDF98E6F45431D.jpg[/IMG]
Old Jul 27, 2008 | 02:40 PM
2000 G.T.'s Avatar
2000 G.T.
I FOUND THE CHIP... WHAT A PAIN IN THE ACE .. DIABLO SPORT.. WHAT IS THE AVERAGE H.P. GAIN. THANKS
[IMG]local://upfiles/92494/B5D30E11A4CE4F9EB157DD669548A9F8.jpg[/IMG]
[IMG]local://upfiles/92494/DAD1FA59EC7D43FEB2098F69A5509AC4.jpg[/IMG]
Old Jul 27, 2008 | 02:43 PM
2000 G.T.'s Avatar
2000 G.T.
FRONT VIEW
[IMG]local://upfiles/92494/634F231928D145D4953392A70DB33F5B.jpg[/IMG]
Old Jul 28, 2008 | 03:08 PM
tfyzorg2's Avatar
tfyzorg2
wtf do u keep pimping your car pictures for?
Old Jul 28, 2008 | 03:17 PM
bb816331's Avatar
bb816331
I ♥ Acer
^^^[sm=funnypostabove.gif]
Define...chip...?
If so, I was unaware diablo made an actual plug in chip...or are you referencing to a hand held tuner?
Old Jul 28, 2008 | 03:25 PM
92stangerang
diablo also does the plug in ecu type...but.... i had mine done from a dyno shop. he put the chip in the ecu and dynod it 3 times for 400 bucks. if i remember correctly from stock to ... chip, exhaust, and intake(k&n) it was about a 30 hp increase. it kinda sucked because once i did something drastic then i had to go back and get it tuned. but then again i was'nt running to rich or lean either. and no code popping up. it also recalibrated my speed when i got a 4.10 gear. vs getting a speedo gear.
Old Jul 29, 2008 | 09:07 AM
acascianelli's Avatar
acascianelli
WHY DO YOU KEEP TYPING IN ALL CAPS. IT'S A LITTLE ANNOYING...
Can you post pictures of the chip, I'm curious to know what part it is.
Old Jul 29, 2008 | 08:53 PM
2000 G.T.'s Avatar
2000 G.T.
its a plug in type. diablo sport chip. it was in the car when i bought it. i've been trying to contact the owner to see if the car was tuned after all the mods. no call back yet. the chip looks like the sct 4 bank plug in chip on american muscle .com. same pull tag and everything but its diablo sport. car has... rock crusher- short throw shifter, 373 rearend, bbk longtube headers w/ off road h pipe, bbk mufflers, steeda lowering springs,ford racing- upper plenum, 90 mm mas air, k&n cold air, 275/40/17 tires and rims, sub-frame conn, stage 2 steeda clutch.
