Difference between these two same-model exhausts?
Old Jul 26, 2008 | 02:08 AM
CheesyBeef's Avatar
CheesyBeef
I ♥ Acer
Default Difference between these two same-model exhausts?
Hi, I'm looking to get one of these flowmaster 50 series cat-backs. Apparently there is 2 versions of the flowmaster 50s, one is $100 more expensive than the other. The only difference I can tell from the description is that the more expensive one has "stainless steel OEM style tips." Does this mean that the whole system is stainless steel and the $100 less system is aluminum or something?
I have been assuming that the $100 more is just for the tips. I would appreciate it if you could check out the two different systems and see if you know the difference.
Flowmaster 50 series ($437.00) - Looks aluminum??
Flowmaster 50 series ($537.00) - Looks steel??
Also, the more expensive one looks like it has welded joints and just looks like a higher quality.
Thank you.
Old Jul 26, 2008 | 06:07 AM
ewgoetz's Avatar
ewgoetz
Default RE: Difference between these two same-model exhausts?
Post links to where you see them...or part numbers to look at.
Old Jul 26, 2008 | 10:13 AM
CheesyBeef's Avatar
CheesyBeef
I ♥ Acer
ORIGINAL: ewgoetz
Ah man, sorry.. It was late at night and I forgot to add links! Thank you for telling me []
Old Jul 26, 2008 | 11:28 AM
Gary H's Avatar
Gary H
The more expensive one has stainless tips.
Old Jul 26, 2008 | 11:33 AM
CheesyBeef's Avatar
CheesyBeef
I ♥ Acer
ORIGINAL: Gary H
Do you think it is also steel piping and the other one is aluminum?
Old Jul 26, 2008 | 12:03 PM
OnyxCobra's Avatar
OnyxCobra
ORIGINAL: CheesyBeef
ORIGINAL: Gary H
nope, both kits are aluminized steel. The only difference is the more expensive one has stainless tailpipes. Honestly if you're gonna spend $400-500 i wouldn't get flowmasters.
Old Jul 26, 2008 | 01:12 PM
945LSTANG's Avatar
945LSTANG
i think you will probably be disappointed with the 50 series.
if you really want flows you should check out the super 44s.
Old Jul 26, 2008 | 02:39 PM
boduke0220's Avatar
boduke0220
yea it'll have a rumble not nothing loud
ak98
Feb 18, 2023 08:36 AM
Sep 10, 2015 08:39 PM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
robjh22
Suspension
Sep 8, 2015 12:47 PM
Emblazoned
Sep 3, 2015 10:45 PM
