high/low compression pistons
Old May 12, 2005 | 02:20 PM
huntnfish08's Avatar
huntnfish08
Default high/low compression pistons
lets say you have your car tuned for standard compession pistons. Can you just add dished(lowcompression) pistons with out anything else to go to a low compression set up suitable for a turbo? I plan to run N/A tuned for best quarter time with that set up and then add a turbo and dished heads. Will it be just that simple or will I need more mods to get it to work?
Old May 12, 2005 | 02:55 PM
86gt5.0HO's Avatar
86gt5.0HO
Default RE: high/low compression pistons
is it fuel injected?
Old May 13, 2005 | 12:55 AM
luckythirteen13's Avatar
luckythirteen13
how much boost are you going to run? you should be able to run 15psi-ish with the stock pistons. if your going to be running a ton of boost you well defenitely have to upgrade the fuel system
Old May 13, 2005 | 12:57 AM
dc_mann8's Avatar
dc_mann8
15 psi on stock pistons? ......................................[&:]
Old May 13, 2005 | 01:01 AM
fordguy17's Avatar
fordguy17
ORIGINAL: luckythirteen13
no way! 9 psi is about the most you want to go on a stock motor. after that you will start lifting heads and blowing head gaskets. even with 9 psi you will need to upgrade your fuel system. (pump, injectors, fpr)
Old May 13, 2005 | 02:48 AM
huntnfish08
plan to upgrade to 42# injectors, 15-20 #s of boost(alky injection)
baddog671
Jul 26, 2016 01:20 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
bconboy
Sep 21, 2015 12:52 PM
uberstang1
Sep 20, 2015 06:42 PM
PNYXPRESS
Sep 14, 2015 09:50 PM
